Problem with Pandoc reference List/zotero intefration
I guess it is a very simple problem, but I am kind of stuck…
I want to connect Zotero and Obsidian using a template that imports also all my comments and marks in Zotero. It used to work, but now I get an Error: “Error retrieving item data: TypeError: get2(…) is undefined.”
The Zotero search bar is still opening, and in there I also can search for the papers.
I used a much simpler template, but that didn’t change anything, I tried different ways to connect Zotero and Obsidian (Port or path) both having the same problem.
Thanks a lot!
Had the same problem. Downgrading Better BibTeX worked for me. Don’t know how much to degrade but 7.0.22 works for me.
I have the same problem. I use macos x sequoia. I do not want to downgrade since I believe it is trsnferring the problem.
I also downgraded to a previous version of Better Bibtex and that solved it. Not the first time.
