Problem with FROM path
Hey new user here, i tried out datawiew and did a list it worked for all notes,
but when i add FROM “folder/folder” it dont show any source any idea whats wrong? ive followed toturials but it just dont seem to work for me
TERRÄNGTYPER is not the same as Terrängtyper, even though both types of terrain are spelled the same. Case matters.
Update: Also, as you found out, be aware that you’re using forward slashes between the folder parts, / .
i’ve tried both. even copied the names from the folders. still dont work
it did work when i tried another solution. Thanks for the tip.
The first when copied file path from explorer had the wrong slash type
then i just tested edit it and it worked.
