Problem with Dataview not filtering to specified date
I’m using Journals add-on with multiple journal (general one, workout log, language learning log). I wanted to automate linking between them with dataview. Journals mark the files with with journal field to assign the journal and journal-start-date and journal-end-date to mark the time
I came up with this code, but it doesn’t show the other notes from the same day
list
FROM "01_LOGS"
where contains(journal-start-date,2024-09-16) and journal != "life"
I run this script without the start date parameter, or with != for the date and it showed me all the notes that it should have.
I must be doing an error with the format of the date somewhere, and would appreciate help.
Symilar code, for the monthly sum up of my gratitude journal
list gratitude
from "01_LOGS/01_life/daily"
where gratitude and journal-start-date.month = 09
works ok
Don’t know the Journal add-on, but does the query below work in your vault?
```dataview
list
FROM "01_LOGS"
WHERE contains(journal-start-date, date(2024-09-16))
AND journal != "life"
You’re a godsend. Thank you for your help.
