Problem with an empty object as frontmatter content
When deleting all properties of a note programmatically, I intended to leave an empty object, to indicate that this note needs some properties but is left empty temporarily. Then the frontmatter in the source mode would look like
I though there would be a UI with no property line but only an Add property button in both reading and live preview modes.
Nothing would shown up under reading / live preview mode. Neither Properties UI, nor error hint (invalid frontmatter etc.)
Either adding an empty properties UI, or providing error hint on empty object would be quite helpful. Currently, if users are handling notes with these “occupied” frontmatters in live preview mode, they won’t be able to create properties by typing ---, as it will be recognized as a separator.
Obsidian version: v1.4.16
Installer version: v1.4.13
Operating system: Windows 10 Home China 10.0.19045
Catalyst license: insider
Insider build toggle: on
Legacy editor: off
Plugins installed: 1
Plugins enabled: 1
1: Projects v1.17.0
I don’t know if this will be considered a bug or not, but you could try this for now:
Thanks for the response! Unfortunately this won’t work, the front matter you provide will result in a field named as {}.
I’ll wait for the official feedback for a better consistency on handling empty properties anyway.
Same behavior on empty yaml content
This is not a bug, it is currently intentional. Please open a FR.
Thanks for the clarification, the correponding FR is here.
