Prevent zip files auto-unzipping on click?
I’m using Obsidian to manage a large project (a house build). I am using it to consolidate and annotate the various files we receive from contractors, so I have “Detect All File Extensions” switched on so I can see all of the various files.
Some of these are .zip files (eg “Kitchen Design.zip”). If I click on these - even a single click - then Obsidian will attempt to open them (even though Obsidian won’t open them “natively”) which causes them to be un-zipped, creating a new folder for the contents of the zip file (“Kitchen Design”). The original “Kitchen Design.zip” file remains, so the effect is that the folder with the original zip file contains a new folder - it’s not always obvious what happened, so I end up clicking several times on the zip file creating multiple folders with similar names (“Kitchen Design 1”, “Kitchen Design 2”, “Kitchen Design 3” etc)
It is definitely useful to be able to open the zip file directly from Obsidian - but just once - not every time I inadvertently click on the zip file.
Is there any way to stop zip files from being automatically unzipped? A “Do you want to unzip this file?” would be useful!
Thank you
PS: I am running on macOS.
Searching online and in this forums - I couldn’t see anything appropriate.
I have switched off “Open ‘safe’ files automatically” in Safari to try and prevent the auto-opening but this didn’t help.
Hello.
I don’t know if it is possible to change the behaviour, and if you are clicking on the links inadvertently then what I have to say next is of no use whatsoever, but if you are clicking on links in live preview because you want to edit them (without opening them) then using the option key as a modifier will make things easier for you: OPTION click should open a link for editing.
Thanks - indeed it’s the inadvertent click I’m trying to avoid. What I’ve done for now is label the file as “DO NOT CLICK: Kitchen Design.zip”, which doesn’t prevent an accidental click but should mean I’m reminded that this isn’t the unzipped file…
