Pressing the SHIFT and Arrow keys can't select text in Chinese Input Mode on Android
Usually when you press the SHIFT and any arrow key, you can select text, but in Chineses input mode on an Android tablet, you can’t select anything, just moving the cursor as if the SHIFT key isn’t pressed. When you change to English input mode, it’s okay.
