To make automated backups without the need for a running desktop system, I’d like to use the Obsidian Sync feature headless in a CLI.
Implement a CLI or provide access to Obsidian Sync API.
This would be amazing — especially if it could be executed from a headless NAS server running Linux. I’m currently relying on the Git plugin and a local repository in the serveron to automate my backups. It works, but is not as good as native obsidian sync.
Yep, I have a VM (linux) that’s running Obsidian and syncing so that it can run the backup. This is a little “brittle” to get it to restart, etc.
I CLI version would be great!
Would love this.
I would love to use Obsidian Sync in a non-GUI mode to sync my Vaults to disk for backing up.
I would use a 64 bit Raspberry Pi, running a 64bit OS with no GUI.
This would potentially work well within a Docker container, where the Vault is stored outside of the container on the local filesystem.
Alternatively, if it’s possible to write a separate Sync program, this would also be fine.
Yes, please! +1²
This is also a half-solution for the gap of not having a web-based version. I could host the files using headless sync and edit them on the remote machine.
I would love an option like that to keep updated my markdown files on some machines where I don’t open Obsidian (also for performance limitations) very often, but where I can still search and open markdown files with other quick viewers/editors.
+1000 love this idea :clap: :clap: :clap:
I would also love to see such a standalone cli for raspberry pi.
Would help in some workflows.
I would also love this… preferably written in golang so as to be easily buildable / portable to different flavors / architectures. Would be a superbe value add for obsidian sync subscribers.
Oh dang, still wanting this :slight_smile:
