Position based nested tags / Attribute-Value Tags - Tags for tags
I use tags to organise books.
It is a series of nested tags:
setting/Event/Miracle/Regress/Once
setting/Theme/Adventure/Searh-For
setting/Age/Resurection/High
and more
setting, is used to limit tags to only books, it would be nice if i could to limit them, but whatever.
Next step is also fine.
But after that…
setting/Event/Magic/Regress
Make it hard to search for /Regress.
I could make it setting/Event/Regress/Miracle
But then, it create a lot of duplicate tags. Like i will have
Regress/Miracle
Return/Miracle
and more.
And that is only the beginning.
I am unable to add anyhing to in between, as it will create a new tag-
Miracle/Regress
Miracle/Gift/Regress
Searching for “Miracle/Regress” will not show you the Miracle/Gift/Regress
as it is “Miracle/Gift”
setting/Event\Miracle/Regress\Once
Where \ dose not change the level of the nested tag.
So searchig for both of setting/Event, setting/Miracle
Will give it as a result.
That way it creates limited aliases for tags.
It is not a perfect solution, but it is the simplest there is.
