Plugin submission Portal problem: ID with spaces are illigal, but can not removed/edited
Hi,
I accidentally published a plugin (via the website) that contained a space in its id.
I’ve since fixed it on GitHub, but how do I get it fixed in the community directory? I can’t delete or edit it. Does the community directory automatically pull the correct data from GitHub after some time?
Could anybody please clear this entry so I can resubmit?
which entry?
grafik
Hi @andreas13xxx, we have resolved the issue with being able to submit entries with spaces in the ID. As part of that fix, I removed your entry. All you need to do now is re-submit your plugin.
Let us know if it gives you any trouble!
Could you delete my submission, please. It is still there. Thanks in advance!
Ah, sorry about that. Now it should be cleaned up.
