Plugin: Labelled Links - say how two notes are related, and see it from both ends
Disclaimer
Community Directory: labelled-links
When Alice links to Bob, nothing tells you whether Bob is her child, her employer or a book she mentions, and from Bob’s side the link is just another backlink. You probably already write the answer down, as child: "[[Bob]]" in the properties or employer:: [[Acme]] in the text.
With this plugin enabled, that becomes a labelled relation, shown wherever you meet the link.
  • A badge on the link, in Reading view and Live Preview.
  • The inverse from the other end: declare parent <-> child once, and Alice’s child link reads as parent on Bob.
  • A relations pane that lists every relation of the active note, in both directions.
  • A hidden label when you want one: [[Acme]]%%:employer%%.
  • It never writes anything into your notes, so the vault reads the same without it. It works alongside Breadcrumbs: Breadcrumbs builds hierarchies, and this labels the individual links.
Alice links Bob as child, so Bob reads it as parent
The demo vault shows every feature on sample notes, so you can try it without touching your own vault: Labelled Links: Open demo vault.
