Plugin combination for Properties entry
On creation of a new note be presented with a modal form that has fields that allow me to choose a value from a pre-defined list. These values are then stored as properties in notes. Examples of the values I would like to select/define are:
Folder location (on save)
Date created
Tags (multi-select)
I would be grateful if people could suggest an optimal solution for this that they use successfully.
Played around with the following plugins with no particular sucess:
Templater
Modal forms
Metadata menu
Quickadd
I have also searched forums and documentation for plugins.
Many thanks, Simon
