Bases support is great. ![]()
Can we expect support for our own properties? This can be configured in the “Chronos Timeline” preferences panel.
Examples:
start - fixed to → debut
end - fixed to → fin
description - fixed to → flash
Examples:
@allervoiretregarder working on this - developing with bases is a tricky new experience for me! agree it’s needed
Chronos Timeline with Bases View is spectacular!! Thank you!!
is there a way to completely disable the ai integration/functionality? this plugin looks like it’s exactly what i need, but i don’t want that crap anywhere near my pc.
Good question.
and @JamesKF
Absolutely, from the settings you can ensure “Use AI features” is toggled off.
AI is completely opt-in and nothing is sent out of your device without you setting up an AI provider.
Sorry, how can we set a different height for the Timeline on a Bases view?
The Events sometimes overlaps the Period names when you have many elements ![]()
I seem to not be able to use the AI function. It keeps responding with Request failed, status 429
Love the look and utility. I plan on using this tool for my D&D game. Is there a way to move the current day mark to a particular date in time so I can have it at any year I’d like it to be instead of defaulting to today?
Thanks for the feedback! There currently isn’t a way to move the “today” red line. However, if you’d like to focus on a particular date, you can use a combo of flags to disable the today line, default a view to a certain date, and add a marker
> NOTODAY
> DEFAULTVIEW 1000|2030
- [1000~3000] foo
= [1500] my marker
Sorry just seeing this now - have you tried it recently with latest updates? If you continue to have an issue, please share which provider/model you are having an issue with
Is there a way to add flags to a Chronos Bases view? I want to remove the Today marker and to change the default view
Did something change in the Bases view with the latest update? It used to work with my notes, even though my system’s date format is set to DD-MM-YYYY instead of YYYY-MM-DD.
Now, whenever I try the Bases view, I just get a “No results found!” message.
Thanks for the plugin, in any case!
