- Install some community plugin
superstition plugin - monitor how community plugins spam the right side panel for several days (1-3 days)
- even after deactivating community plugins, spammed popups persist in the right side panel and aren’t purged by Obsidian.
Y
After deactivating a buggy plugin (which spams the right side panel with pop-up choices - please see attached picture), Obsidian should do some cleanup / purging to remove missing 3rd party plugin entries, instead to show “plugins no longer active” (at least on phone). I know the root issue was the superstition plugin, but Obsidian should do some cleanup too.
Deactivating, then uninstalling the plugin causing this issue didn’t help, Reloading, quitting Obsidian then restarting the phone didn’t help either. How to get rid of this long list of useless entries?
Selecting these buggy entries doesn’t remove them, but makes Obsidian jump to a valid plugin entry then “Plugin no longer active” takes over its name.
Operating system: android 11 (motorola moto e40)
Obsidian version: 1.7.7 (171)
API version: v1.7.7
Base theme: light
Tab and hold the “plugin no longer active” popup button for a second or two, to manually remove invalid pop-up buttons, one by one. The only solution, but takes a lot of time, whereas purging duplicates would be immediate
The list on this screenshot is twice as long, always with the same “Plugin no longer active” warning.
