I would like to be able to tag without remembering the tag name, instead knowing its place relative to others in sequence of tags. This could be accomplished by making the suggestion drop down persistent like with linking. I could just scroll through to about where I thought my desired tag should be.
I am thinking that using prefixed tags with persistent a-z sorted suggestions, having a weak short term memory wouldn’t make this type of tagging so strenuous.
Welcome!
It’s a good idea, thanks for sharing.
Just a tip: your post was a wall of text—breaking your points up into smaller paragraphs will help others skim them to get the idea!
