I believe it’s either a file in your vault or the some of the generated files contain some weird character that breaks our caching algorithm.
You can attempt to figure out where the problem is by
- Close Obsidian
- Remove 1 canditade file from your vault (i would start with the files you have generated with the bat script)
- Remove the cache
- Start Obsidian and see if it works or not
- If it’s not working, Repeat the process
If you find the file (or the part of a file) that creates problem, let us know.
