Pasting images with Quickadd/Templater
Hi, I’ve noticed that when using Quickadd “{{clipboard}}” doesn’t paste images, and I was wondering if there’s a way to insert clipboard images with templater or quickadd, or anything else.
Thanks.
Probably can do with js, but because you can have a single image in the clipboard anyway, you may just as well paste it in the desired line after the note was created…?
