Parse Data into Notes and format using Regex from Clipboard
Ive tried searching but have not found exactly what I am looking for and maybe someone can point me into the right direction.
I have switched over to obsidian for my note taking but one ability would make things alot quicker.
My notes often include things like names, phone numbers etc. I would like to be able to copy from my ticket system a section into my clipboard.
Then paste/parse the data into my notes and fill out those sections using regex instead of using pop up inputs for each.
Any thoughts?
If you use the Templater plugin it’s capable of reading the clipboard, and then you could do whatever you want with it, and populate a proper section based upon it.
It requires a little coding, but it’s very doable.
