Hi I am trying to follow along with this tutorial: https://www.youtube.com/watch?v=W_leEJHBZW4
and for the first Habit tracker, I am getting this error: “Parameter ‘searchType’ not found in YAML”
Here are some screenshots:
I have tried tweaking the inputs, but I am very new to this and learning, so I am totally lost.
Thanks in advance!
I retyped it, and then it gave me a date Error, so I switched it from “Tuesday, September 4th, 2023” to “2023-09-05” and now it is giving me this error: “No valid Y value found in notes”
Pch
September 5, 2023, 12:07pm
3
I don’t use Tracker (which is rumoured to be “abandoned”) but have you tried to use Dutch
instead of dutch
for the searchTarget
Yep, that didn’t work either.
Pch
September 5, 2023, 1:00pm
5
So, I apparently got the plugin to work using this :
```tracker
searchType: frontmatter
searchTarget: dutch
line:
Note the searchType
vs. searchtype
from your screenshot (maybe ?)
The note I used was named 2023-09-05.md
and contained only this frontmatter :
dutch: 1
Thank you! I will try this.
