I am having issues with my main pane size. It will not display the full pane. Instead, it gives me a small window that I have to scroll through. I have attached a screenshot to show the issue.
Do you have the “Readable Line Length” setting in “Settings” → “Editor” turned off? That should expand pages. Beyond that, “readable line length” is probably a good search term on this forum for threads where people have recommended other strategies.
I do have it turned off and nothing works. I’ll check some of the other threads, then, and see if I can find something.
I found the issue! It was one of my plugins (Outliner) that needed to be updated.
