Hi,
I’m following this article and I got stuck at the section about Figures and Section referencing using Pandoc-crossref.
Anyone here using it on Mac + Pandoc installed via Macports? Basically his instruction is “use homebrew or it won’t work” but I canno’t install Homebrew on my old mac.
So Pandoc via macports and then I managed to install Pandoc-crossref manually.
I copied the exec in both /usr/local/bin/ and /opt/local/bin/, just in case…
But for some reason Obsidian won’t see it
I just don’t know how Obsidian is supposed to see it and get this kind of syntax for figure labelling / numbering to work
Now, all you need is to write {#fig:your_fig_name} next to your figures as such:
And in-text, reference the figure with: @fig:your_fig_name
Anyone has an idea that could help ? Thanks in advance !
