Outline: Unable to drag lower heading to top position in outline view
  1. New note
  2. Make a few headings
  3. In the outline tab, try dragging a lower heading to the very top - can’t (it worked once, and I don’t know what was different)
(I was able to reproduce this in a Sandbox vault)
The dragged lower heading to go to the top of the outline.
Dragging a lower heading to the top resulted in no change.
Obsidian_GTLTWlfNlJ
Obsidian version: 1.12.4
Installer version: 1.10.3
Operating system: Windows 10 Pro N 10.0.19045
Catalyst license: none
Snippets enabled: 1
Plugins installed: 7
Plugins enabled: 4
1: Hotkeys for specific files v1.4.1
2: Excalidraw v2.19.2
3: Recent Files v1.7.6
4: Tag Wrangler v0.6.4
(Thanks for all your help.)
Closest I got to a related post is Outline - Drag and drop headings doesn’t work, but that isn’t quite the same.
4 posts were merged into an existing topic: Can’t drag heading to top or bottom of Outline
