Outline tab does not stay collapsed and scrolls while typing (expands, unfolds headings)
I’m still seeing the bug described in this topic, with the Linux AppImage v1.8.4 on KDE:
Since the topic was closed to updates, I’m starting a new one.
  1. Start a new note with the following markdown:
    # Heading 1
    Contents for heading 1
    ## Heading 2
  2. In the Outline pane, collapse Heading 1:
  3. Make any edit, such as deleting a character from the contents of Heading 1:
Yes
The Outline should persist its folded state, at least for the current tab and within the session (ideally between restarts).
The Outline expands all headings.
Obsidian version: v1.8.4
Installer version: v1.6.7
Operating system: #1 SMP PREEMPT_DYNAMIC Thu May 2 18:50:49 UTC 2024 6.8.9-100.fc38.x86_64
Snippets enabled: 1
Screencast available upon request.
Yeah, I’ve been experiencing what I believe to be the same bug, in a slightly different form. I don’t normally keep my Outline collapsed, but I do have some long notes with dozens of headings, and the outline constantly flickers/jitters while I’m typing in those notes. (Just tried collapsing the outline in those, and the normal flickering behavior expanded them again.) This has been happening for a 1-2 years, at least, really looking forward to the bug fix.
Edit: yes, a couple other replies to this thread mention the same thing.
Hi, mine does the same thing, also in long documents. I can’t work with the outline jittering all the time, i have to switch it to something else, but that also makes it hard to work, because in the long notes i need the outline. help! thanks
Update - I installed the “Quiet Outline” plugin, and it seems to have solved the problem.
I think this is a bug in core, not something that a plugin should solve?
I still see it in v1.8.7, despite some Changelog entries involving folding.
Hi, Are we talking about the same thing? My problem was that the outline would sort of jump as i typed, it jittered, but didn’t fold or unfold. The Quiet Outline plugin seemed to solve it, since it no longer jitters. Its got some other good functions also.
+1 I am experiencing that the outline expands after I make an edit (while in live preview mode) The outline should not change collapse state as the result of an edit.
will be fixed in v1.9. No ETAs.
