An ordered list with only 1’s will render correctly if written as a markdown outline. But if you use actual numbers in your source text, it appears something is wrong with the section-reset behavior. If I write the following in plain text:
1.
2.
3.
4.
5.
6.
7.
8.
It should render like this:
1.
1.
1.
1.
1.
1.
1.
1.
Or, if I apply custom styling in the APA format, I should get something like:
I.
A.
1.
i.
Instead, the count continues on each indented line from the previous line.
I.
B.
3.
iv.
- Operating system: Mac Catalina
- Obsidian version: 0.6.4
- Using custom CSS: Yes, but it doesn’t function correctly because of the counter-reset or counter-increment issue.
