Hello Forum,
Thank you very much for reading this ticket and your support.
I have my vault located on a Synology NAS that is connected as network drive “S:\Notes” to Windows 11.
With former version 1.12.7 everything is working fine.
After upgrade to version 1.13.4 this vault cannot be opened.
When clicking on it a window opens and then closes instantly without any error message or entry in obsidian.log
- Install version 1.13.4
- Try to open existing vault on network drive (“S:\Notes”)
- Window appears and closes instantly without error message
- Try to create a new vault on network path
- Same behavior as with an existing vault
- Create a new vault on C:\
- Uninstall version 1.13.4
- Install version 1.12.7
- Vaults on network path can be used again as intended
Yes, I tried the following
- Using default config and theme
- Uninstalling all custom plugins, just using default plugins
- Creating a new vault on the network drive
- Vaults on network drive can be opened as in former version 1.12.7
- Existing and new created vaults on a network drive open and close without error message or entry in “obsidian.log” (“C:\Users\[USER]\AppData\Roaming\obsidian\obsidian.log”)
- Cannot reach that far, since vault is not opened long enough
- OS
- Win11 25H2 (Build 26200.8973)
- NAS
- Synology NAS DS723+
- DSM version: 7.3.2-86009 Update 4
- Plugins:
- File Station: 1.4.3-1610
- SMB Service: 4.15.13-3047
- Obsidian
- Working
- Version: 1.12.7
- Plugins
- Calendar: 1.5.10
- Folders to Graph: 1.2.0
- Tasks: 8.3.0
- Tasks Calendar Wrapper: 0.3.2
- Not working
- Version: 1.13.4
- Plugins: none
- Config: default
The team are aware and the fix will be in the next version.
Do you mean the next big version or will there be a bug fix in between?
Boils down to the question should I wait for the fix or use the older version?
A team member can correct me if I’m wrong, but my understanding is that it will be fixed in 1.13.5. ETA unknown, but I reckon shortly.
This is still a problem for me i 1.13.6
Have tried uninstalling 1.13.4 completely and reinstalling, still goes back to the Open Vault menu (Windows 11)
Download and reinstall obsidian. Post a screen recording of this happening. Thanks.
30 Mb is too large.
Can’t slice it.
I’ll describe it to you instead.
- I uninstall Obsidian
- I remove all folders under AppData/Local and Roaming
- I reinstall 1.13.6
- Same problem occurs.
- I’ll start going through the vault now and see if there’s anything I can fix
Upload it somewhere and post here or dm me the link?
Also does it happen with any NAS vault or just that vault?
Tried creating a new blank one, on a different share but still on the same NAS, which worked, so there’s something with that vault. I’ll fix link.
I might have found the issue:
Having the vault in the root of a shared drive, for instance O:\.obsidian makes it crash.
Creating a vault in O:\Obsidian\.obsidian works
that case will be fixed in v1.13.7. ETA unknown
Works fine from W11 - as never failed, also not with 1.13.6 - but open vault on Synology NAS with 1.13.7 on KDE Neon (24.04 - ubuntu-based) Plasma 6.7.4 still hangs. Just tried with Appimage. Yesterday tried 1.13.6 with .deb installed version.
Continued testing:
On KDE Neon the new 1.13.7 Appimage does not work very well: Keeps hanging on opening a vault from Synology NAS and - besides that - the Create new vault button does not react at all.
I think it caused by KDA Plasma or its “KDE neon”-specific implementation. Obsidian 1.13.7 works fine on linux desktop:
my KDE Neon (from inxi)
System:
Host: KDE-neon Kernel: 7.0.0-28-generic arch: x86_64 bits: 64 compiler: gcc
v: 13.3.0 clocksource: tsc
Desktop: KDE Plasma v: 6.7.4 tk: Qt v: N/A wm: kwin_wayland with: krunner
vt: 2 dm: N/A Distro: KDE neon 24.04 User Edition
base: Ubuntu 24.04 LTS Noble
I tested the same 1.13.7 Appimage on an VM (W11 host) with Linux Lite and XFDE: using the same Synology NAS-based vaul: opens fast and works perfect.
Linux Lite is based on the same Ubuntu version:
System:
Host: Obsidian Kernel: 6.8.0-100-generic x86_64 bits: 64 compiler: N/A
Desktop: Xfce 4.18.1 tk: Gtk 3.24.41 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Linux Lite 7.8 LTS
base: Ubuntu 24.04.4 LTS (Noble Numbat)
