While taking notes at work, on my company laptop, I do not want to store my vault locally in the laptop. Hence Obsidian Sync is also not an option for me.
Therefore, I’ve set up the vault in a USB stick plugged in the the company laptop, so that I can physically remove any time.
I still don’t feel secure as the USB stick can be lost and the files are not encrypted nor recoverable.
I came up with the idea of setting up the vault in my Android storage, and use the PC to access the vault via cable and enable file transfer. While I can access the mobile storage with File Browser, the storage is not visible to Obsidian vault opener.
I need a solution for Obsidian to access my Android phone storage, where I can store my vault and gives my the option of backing up my vault files in private cloud and wipe the phone when lost.
Having the vault on a USB stick, which is not really secure.
