Is the result of this OCR visible to you, though, or is it simply used for searches within dropbox? At the moment I have tesseract running on this PC so that I can OCR stuff and get at the results — or you can photograph things on Android and run it through the OCR i MS Office Lens, and then paste the results. They are both annoying workarounds.
