To reproduce this you can go to any page heavy on interactive features and buttons (this is just my observation, the real reason could be something different, but this is just the common thread I see in them). Sites like these are like “wings.io” or “powerline.io”, it seems it can’t open most .io games. Sites like chess.com are a bit weird, you can log in and navigate the page fine, but as soon as you actually try to start a round of chess, the big occurs (page goes grey, locked in the tab until you close it out.)
I did do the above, this is using web viewer (from the latest version of discord). The bug can be reproduced in both, my heavily css-modified and plugin installed vault AND the brand new, clean slate sandbox vault.
I expected the websites to load and to not go grey.
The websites instead didn’t load, and the tab turned grey. As mentioned above, the only way to get out of this is to back out the page or close the tab, the actual content of the website is totall inaccessible.
Obsidian version: v1.8.3
Installer version: v1.6.3
Operating system: Windows 10 Home 10.0.22631
Catalyst license: none
Community theme: AnuPpuccin v1.5.0
Snippets enabled: 21
Plugins installed: 78
Plugins enabled: 74
1: Advanced Tables v0.22.1
2: Callout Manager v1.1.0
3: Excalidraw v2.8.0
4: Execute Code v2.0.0
5: Full Calendar v0.10.7
6: Iconize v2.14.7
7: Kanban v2.0.51
8: Note Definitions v0.27.2
9: Style Settings v1.0.9
10: Text Extractor v0.5.2
11: Unicode Search v0.6.1
12: Nuke Orphans v1.2.5
13: Day Planner v0.27.0
14: ii v1.1.6
15: Solve v1.1.0
16: Meta Bind v1.3.3
17: Admonition v10.3.2
18: Homepage v4.0.7
19: Settings Search v1.3.10
20: Paste URL into selection v1.7.0
21: Templater v2.9.2
22: Convert url to preview (iframe) v0.5.0
23: Pomodoro Timer v1.2.3
24: Markwhen v0.0.3
25: Heatmap Calendar v0.7.1
26: Personal Assistant v1.4.8
27: List Callouts v1.2.9
28: POWER MODE v1.0.8
29: Hide Sidebars on Window Resize v1.1.0
30: ProgressBar v0.6.0
31: File Cleaner Redux v1.4.1
32: Media Notes v1.3.0
33: Note Toolbar v1.17.0
34: Share Note v0.8.17
35: Code Styler v1.1.7
36: ePub Reader v1.0.2
37: Dialogue v1.0.2
38: Mathpad v0.8.14
39: Image Toolkit v1.4.2
40: Periodic Notes v0.0.17
41: BRAT v1.0.6
42: Badges v1.1.0
43: Commander v0.5.2
44: QuickAdd v1.11.5
45: Waypoint v2.1.0
46: Calendar v1.5.10
47: Callout Integrator v1.1.4
48: Callout Suggestions v1.0.2
49: Latex Suite v1.9.8
50: Customizable Menu v2.2.0
51: LanguageTool Integration v0.3.7
52: make.md v1.0.8
53: Wordy v1.3.1
54: Tracker v1.15.0
55: Omnisearch v1.25.2
56: Importer v1.6.19
57: Custom Frames v2.5.0
58: Living Graph v1.0.3
59: CSS Editor v1.2.3
60: Linter v1.28.0
61: File Info Panel v1.3
62: ProZen v0.3
63: Ink v0.3.3
64: Random Number Generator v1.0
65: Enlightenment v1.2.1
66: Smart Links v1.0.2
67: Fast Text Color v1.1.4
68: Image Layouts v0.15.5
69: Colored Text v1.2.0
70: Collapse Node v1.1.1
71: Advanced Canvas v3.5.0
72: Iconic v1.1.0
73: Dataview v0.5.67
74: Ninja Cursor v0.0.13
I understand there are alot of plugins, but once again, even in a clean sandbox vault this bug occurs.
This issue also happened with the surfing plugin.
