Sometimes the entire system freezes and the only solution is to hard reboot the computer. This started happening in v1.0.0. And it doesn’t happen when using any other apps.
Operating system: Fedora Workstation 36
Debug info:
Obsidian version: v1.0.0
Installer version: v1.0.0
Operating system: #1 SMP PREEMPT_DYNAMIC Thu Oct 13 18:58:38 UTC 2022 5.19.15-201.fc36.x86_64
Legacy editor: off
Base theme: light
Snippets enabled: 1
Plugins installed: 4
Plugins enabled: 3
1: Advanced Tables v0.17.3
2: Excalidraw v1.7.24
3: Latex Suite v1.5.2
I am having this same issue, also on Fedora (Silverblue 37, GNOME/Wayland) - however, it doesn’t catastrophically crash the entire system, it just locks it up for maybe thirty seconds before unfreezing.
Notably, when it unfreezes, the graph views turn completely blank (I have both the global and local views in my sidebar), which suggests that’s what snapped. The developer console shows a few warnings about “WebGL context lost” as well.
Debug info:
Obsidian version: v1.0.3
Operating system: #1 SMP PREEMPT_DYNAMIC Thu Oct 13 19:00:55 UTC 2022 5.19.15-301.fc37.x86_64
Legacy editor: off
Snippets enabled: 3
Plugins installed: 6
Plugins enabled: 5
1: Obsidian Charts v3.6.3
2: Tag Wrangler v0.5.4
3: Dataview v0.5.47
4: Icon Folder v1.3.5
5: Templater v1.14.3
I have the same issue, and it is with my ipad and samsung tablets.
Not the system per se, but obsidian itself crashes.
It could be related to the excalidraw plugin not working well with the new obsidian, but that is essential for my workflow
I have the same issue on arch linux with dwm, and only when running obsidian. My entire system freezes, for like dozens of seconds (but my audio keep working while the system is frozen)
CPU: 12th Gen Intel i7-12700H (20) @ 4.600GHz
GPU: Intel Alder Lake-P
GPU: NVIDIA GeForce RTX 3060 Mobile / Max-Q
The issue happens both with the integrated gpu (i.e. the dgpu is completely turned off) and the dgpu (my laptop has a mux switch which shuts down the iGPU and only uses the dGPU)
Haven’t checked if --disable-gpu works, but that’s not a viable option for me because the resulting interface would look bad.
I can confirm similar behavior on Ubuntu 22.04. When using Obsidian, the app will occasionally freeze and become unresponsive to user input for about thirty seconds. During this time the rest of the OS is responsive and behaves normally. Then Obsidian becomes usable again.
I haven’t found any pattern yet to when it happens or why. I’ll post more if I find anything useful.
It turns out this is not an issue with Obsidian, but rather an issue with GPU drivers on Intel Alder Lake.
Using options i915 enable_psr=0 as mentioned on that issue worked for me as a workaround, and Obsidian stopped freezing. Turns out the option didn’t help, and I actually just disabled hardware acceleration and forgot about that. It’s still an issue with the drivers though, not with Obsidian.
