Obsidian Publish Favicon Not Showing Solution
Continuing the discussion from Can't change favicon:
I had the problem where I would add a favicon to obsidian publish but it wouldn’t seem to show in the browser. The problem is that browser would hold on to the old favicon because of caching. So to reset the cache, you have to use the shortcut [ctrl + shift + R] and that fixed the issue for me
