Obsidian not opening on arch DWM
I have been trying to get Obsidian installed and working on my system and I am getting an error that I have found no working solutions for.
I am running Arch Linux with DWM.
Below is the error that I am getting when I run the program.
2025-07-05 00:19:20 Loading main app package /usr/lib/obsidian/obsidian.asar
[2562183:0704/191920.531321:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.DBus.Properties.Get: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.InvalidArgs: No such interface “org.freedesktop.portal.FileChooser”
[2562183:0704/191920.531352:ERROR:select_file_dialog_linux_portal.cc(308)] Failed to read portal version property
2025-07-05 00:19:20 Checking for update using Github
Even I’m facing this problem while trying to install obsidian. I’m using Arch and hyprland. I tried installing both from pacman and from AUR. Both give me this error. I have another system where I had installed a while back with no issues. It error seems to be related with the new package.
The Flatpak version works better than installing from package management. I am using EndeavourOS which is Arch based.
