Obsidian Life RPG: A Zero-DB Gamification Vault (CustomJS + Dataview)
Hey everyone! :waving_hand:
I got completely burned out by standard, lifeless to-do lists, so I decided to turn my daily routines into a full-fledged RPG. I wanted to share the custom vault framework I built for myself: Obsidian Life RPG.
Disclaimer (The AI Manifesto): As noted in the vibe-coding section above, I am not a hardcore TypeScript developer. The entire architecture, the pure JS engine, and the Dataview scripts were engineered by me alongside AI. It’s a bit scrappy, but it works flawlessly for my needs, and I’m releasing it AS IS under the MIT license. If you see code you don’t understand—just feed it to ChatGPT/Claude and tweak it to your liking!
What makes it different? (Zero-DB Architecture)
I didn’t want a fragile global JSON file or a bloated central database that could corrupt my whole game. Instead, the engine (RPG_Engine.js) uses event-sourcing. It dynamically scans your daily logs (05_Journal) and projects on the fly every time you open the dashboard. Your stats (HP, Gold, XP, Level) are calculated safely from your markdown history.
Core Features:
  • Dynamic Economy: Earn Gold and XP for deep focus and completing tasks (using inline tags like [difficulty:: Easy]).
  • HP & Discipline: Procrastination or failed quests deal damage. Drop to 0 HP, and your gold income is slashed by 50%.
  • Epic Quests: Long-term projects pay out in quartiles (25%, 50%, 75%, 100%) to prevent dopamine starvation.
  • Gamified Zettelkasten: The engine grants passive XP for every conceptual note you write in your Second Brain.
  • Yearly Heatmap: A GitHub-style matrix with absolute focus thresholds (rendered via Shadow DOM to prevent lag).
Requirements:
It runs on pure JavaScript inside Obsidian using:
  1. Dataview (Enable JS Queries & DataviewJS)
  2. CustomJS
  3. Templater
I’ve packed everything into a ready-to-use Vault structure. Since my account is new and the forum spam-filter doesn’t allow me to post links yet, you can easily find the project on GitHub:
:magnifying_glass_tilted_left: Search on GitHub for: Obsidian-RPG-Life-System-EN
:bust_in_silhouette: Author: Valluk13
Feel free to download it, break the balance, add new items to the Shop, and use it to conquer your own tasks. Let me know what you think!
Cannot find it :pensive_face:
I’m really interested on trying out your vault. Did you change its name by any chance?
