Hello ! I just want to open notes on my Obsidian but for days now, my Obsidian vault is lagging in a way that it is unusable.
When I open the vault, a pop-up on the upper-right corner says : “Obsidian index your vault”.
Moreover, when I try to open a note, it open an empty note called “No file” and there is nothing on it. After 2 or 3 minutes, the note would finally open.
I try to desactivate the plug-in that I had to see if it was my computer that couldn’t support the plug-ins (Periodic Note, templator, dataview, folder note, homepage, omnisearch…) even if everything was working before.
I was thinking about a problem due to my cloud (i’m on Kdrive) and so i subscribe to Obsidian Sync for this month to see if it was this problem but nothing change.
If you have any ideas on this issue, i would be grateful !
Thanks !
