Every time I start up Obsidian, it’s in split screen mode (top/bottom). It’s inconvenient because whenever I close it, it closes the entire tab. I’ve looked around settings but haven’t come across anything that turns it off. Anyone else having the same issue and/or know what’s causing it?
Can you share a screenshot?
I saw mentioned a few times that the Creases(?) community plugin was causing something like that.
I’d try the debugging steps to see if it’s a plugin or theme causing it.
Yup, it was the Creases plugin! I’ll post the solution here once I find it
Deactivate the obsidian plugin “outline” and the problem is gone.
(Quiet outline plugin is a good replacement)
Is someone able to fix the problem in creases plugin? Even a manual hack would be appreciated.
