Obsidian keeps reloading every couple of minutes
  1. Open any Document from a vault
  2. wait couple of minutes and it should happen
Y
That the document doesn’t reload every couple of minutes and I can keep working
It reloads every minute or so
Obsidian version: v1.4.16
Installer version: v1.4.16
Operating system: #1 SMP PREEMPT_DYNAMIC Debian 6.5.10-1 (2023-11-03) 6.5.0-4-amd64
Legacy editor: off
What version are you running? AppImage, Snap, etc.?
Post a screenrecording of this happening in the sandbox vault.
In step 2 you say “wait couple of minutes”. Does it actually happen if you just sit and wait, or is it while you’re working/typing?
If typing: One other thing to double check is if you mapped any hotkeys to a command such as Reload app without saving.
