Obsidian Kanban: How to Confirm a Card with Enter on Android/Chromebook
Hi everyone,
I’m using the Kanban plugin in Obsidian on a Chromebook (Android version of Obsidian), and I’m having trouble confirming a card after adding it.
When I press Enter, it creates a new line instead of saving the card.
I checked the “Next line trigger” setting, but changing it doesn’t seem to affect the behavior.
I also tried Ctrl + Enter, Shift + Enter, and other combinations, but none of them worked.
Is there a way to confirm (save) a card using the keyboard on Android/Chromebook? Or is this a known limitation of the plugin on these platforms?
Any help would be appreciated! Thanks. :blush:
