Obsidian Headless Sync on Linux VPS gives ReferenceError: WebSocket is not defined though wss is not blocked
Set up Obsidian headless sync on a DigitalOcean Linux VPS.
I installed using “sudo npm install -g obsidian-headless”
Then I did “ob login” and I get below error:
I checked that websocket is enabled on the machine doing the following:
“sudo npm install -g wscat”
And then“wscat -c wss” to echo websocket org
I get echo reply on any message I send.So seems like websocket isn’t restricted.
Any ideas?
WebSocket Headless Sync
You probably have a Node.js version that is too old. I ran into the same error, and the default version of Node.js in Debian 13 is 20, which doesn’t have the stable WebSocket API. I installed a newer version (24) and now it works fine.
