When I launch Obsidian I get the message:
An error occurred while loading Obsidian. TypeError: Cannot set property ‘pane-relief:history-v1’ of null.
No idea why this happened. Obsidian was properly closed yesterday among all other apps before I started OS X Software update.
Button Reload app does not help.
Button Open another vaultopens another vault, e.g. Help vault. No problem there.
  • Operating system: macOS Catalina 10.15.7
  • Obsidian version: 0.12.16
Pane Relief is a plugin. Can you try going into your vault’s .obsidian folder and moving the Pane Relief folder out of your vault? Then relaunch.
Thank you so much!
