Hi, I was using obsidian when I noticed my system resources were high. I finished writing the system and used Command-Q (on MacOS) to quit the app (and all other apps). I subsequently reopened obsidian (straight away) but the note was completely empty. I checked trash and file recovery but they don’t have the note I was working on. All links to the note are gone as well. It’s like the note was just emptied to blank?
I really need this note back, is there any way I can recover it? Is it just some corruption?
File recovery, the latest snapshot was 6 days ago which is not very useful at all.
Recover my note in full!
Try File recovery plugin
Thank you so much, it worked! I tried to do file recovery straight way from the Command-P menu and it only came up with one snapshot five days ago. When I tried it from settings though it came up with all the snapshots. (This behaviour with only one snapshot from Command-P is still the case).
