Run
obsidian create path="Inbox/cli-escape-repro.md" content="# CLI escape repro" overwrite. -
Run
obsidian append path="Inbox/cli-escape-repro.md" content='plain nu: \nu'. -
Run
obsidian read path="Inbox/cli-escape-repro.md". -
Observe the written note content.
N
I have reproduced the issue from the CLI, but this draft still uses my normal vault state rather than restricted mode or the Sandbox vault.
The note should contain the exact literal text plain nu: \nu, with the backslash preserved.
The CLI appears to interpret \n as a newline inside content= values, even when the shell argument is single-quoted. The resulting note is corrupted and becomes:
plain nu:
u
Obsidian version: 1.12.7
Installer version: 1.12.7
Operating system: Darwin Kernel Version 25.4.0: Thu Mar 19 19:33:09 PDT 2026; root:xnu-12377.101.15~1/RELEASE_ARM64_T8112 25.4.0
Catalyst license: none
Plugins installed: 3
Plugins enabled: 3
1: Latex Suite v1.11.0
2: TikZJax v0.5.2
3: Git v2.38.0
This also reproduces with other LaTeX-style control words that begin with \n or \t, for example \theta, \tilde, and \to. In those cases the CLI appears to interpret \t as a tab, so the note content is also corrupted.
I first noticed this through daily:append, but the simpler reproduction above uses append. So this seems to affect at least append and daily:append, and possibly any CLI command that accepts content=....
This looks like an extra escape-decoding step in the Obsidian CLI after shell parsing. Shell quoting alone does not prevent it.
Current workaround: avoid passing raw LaTeX or other literal backslash-heavy text through CLI content= arguments and edit the file directly instead.
