Obsidian cannot open obsidian:// links with spaces in their Note name
  1. Create a note whose name contains spaces - such as “Shopping List”.
  2. Right-click on it and select “Copy Obsidian URL”
  3. Go to a terminal and run xdg-open
Yes, notably this doesn’t work with the Sandbox either. It’s related to core obsidian:// logic, not plugins. Trying to do it in the Sandbox vault also breaks the link because the vault= part for the Sandbox contains a space too.
Obsidian should open the note
Obsidian opens, erroneously interprets the space in the note name as a delimiter and displays ‘File "Shopping’ not found"
Obsidian version: v1.8.9
Installer version: v1.8.9
Operating system: #1 SMP PREEMPT_DYNAMIC Fri Feb 28 07:06:44 UTC 2025 (ff9b7ff) 6.13.5-1-default
Community theme: Sandstorm v1.2.1
Snippets enabled: 1
Plugins installed: 7
Plugins enabled: 7
1: Dataview v0.5.67
2: Commander v0.5.2
3: Plugin Update Tracker v1.6.2
4: QuickAdd v1.12.0
5: Templater v2.9.3
6: Metadata Menu v0.8.7
7: ChatGPT MD v2.0.1
Apparently Obsidian cannot properly interpret the %20 in a file= in the url-scheme as being part of the file name and instead interprets it as a delimiter.
I apparently don’t understand the syntax on this forum lol. Anyway, it is supposed to say
"Go to a terminal and run ‘xdg-open [the link that Obsidian gave you]’
Obsidian interprets %20 fine.
I think the way you are calling the URI may be wrong. Maybe you should enclose in quotation marks to avoid the shell or xdg-open to touch the URI and pass it AS IS.
Sorry, after further debugging it turns out this is a bug in kde-open5, not in Obsidian. I’ll route the bug report in the correct direction.
Once again, sorry for the noise.
