Paste the following into a new note in Obsidian 1.15.0 and open it in Reading view.
```mermaid
config:
themeVariables:
cScale0: "#FF00AA"
cScale1: "#0055FF"
timeline
section First
2025 : Alpha
section Second
2026 : Beta
Also try:
```mermaid
config:
themeVariables:
timeline:
cScale0: “#FF00AA”
cScale1: “#0055FF”
timeline
section First
2025 : Alpha
section Second
2026 : Beta
Expected behavior
The first section appears pink and the second appears blue.
Actual behavior
Both sections use the default colors. The generated SVG has no inline value for --pele-series-1. Setting the same palette with %%{init}%% gives the same result. Setting --pele-series-1 in an Obsidian CSS snippet changes the color.
The same example was tested against the Pele renderer shipped in Obsidian 1.15.0 and against standalone Pele 1.13.0. Only standalone Pele applied the palette from the Mermaid block. The Pele 1.13.0 release notes list support for timeline palette settings.
Debug info
Obsidian version: 1.15.0
Installer version: 1.14.4
Operating system: Windows 11 Pro 10.0.26300
Catalyst license: none
Snippets enabled: 1
Plugins installed: 7
Plugins enabled: 7
1: Copilot v4.0.17
2: Book Search v0.7.5
3: Linter v1.35.0
4: Sidebar Highlights and Tasks v2.7.0
5: Bases Visuals v0.20.0
6: Templater v2.26.0
7: Dataview v0.5.68
