Obsidian 1.14.4 segfaults on launch (Kubuntu 24.04, X11, snap) — works fine on 1.13.7
**App:** Obsidian 1.14.4 (snap, classic confinement, revision 69)
**Platform:** Kubuntu 24.04.5 LTS, kernel 6.8.0-146-generic, Plasma 5.27.12, X11 session
**GPU:** Intel Iris Xe (Alder Lake-UP3 GT2), i915 driver, Mesa 25.2.8-0ubuntu0.24.04.4
## Summary
Obsidian 1.14.4 segfaults immediately on every launch attempt. Reverting to 1.13.7 (still
installed locally as a disabled snap revision) works perfectly every time. This is a clean
version-bisected regression between 1.13.7 and 1.14.4.
## Steps to reproduce
  1. Install Obsidian via snap on Kubuntu 24.04 (X11 session) on Intel Iris Xe graphics.
  2. Launch Obsidian normally, or from a terminal: `obsidian`
  3. Process crashes within ~1 second with a segmentation fault / core dump — no window ever appears, no error dialog, just a crash.
## What I’ve ruled out
  • **Not GPU-rendering-related:** crash still occurs with `–disable-gpu`.
  • **Not Mesa/driver-related specifically:** crash still occurs with
    `LIBGL_ALWAYS_SOFTWARE=1` (forces llvmpipe software rendering, bypassing the Intel driver entirely).
  • **Not sandbox-related:** crash still occurs with `–no-sandbox`.
  • **Not a kernel-level fault I can get details on:** `dmesg`/`journalctl` show no segfault
    entry for the crash despite the shell reporting exit code 139 and a core dump — likely
    swallowed by the snap’s confinement/apparmor layer rather than surfaced to the host kernel log in a way I could capture. `coredumpctl` has no matching entry either.
## Confirmed version bisection
  • Obsidian 1.13.7 (snap revision 68): launches and runs normally, every time.
  • Obsidian 1.14.4 (snap revision 69): segfaults on every launch, with or without
    `–disable-gpu`/`–no-sandbox`/software rendering.
I’ve since pinned the snap to 1.13.7 (`snap revert` + `snap refresh --hold`) as a workaround, so I no longer have a broken daily driver, but would appreciate help fixing this.
Environment details
OS: Kubuntu 24.04.5 LTS
Kernel: 6.8.0-146-generic
Desktop: KDE Plasma 5.27.12
Session type: X11 (verified via loginctl, not XWayland)
GPU: Intel Iris Xe Graphics (Alder Lake-UP3 GT2), i915 driver
Mesa: 25.2.8-0ubuntu0.24.04.4 (from noble-updates)
Obsidian install: snap, classic confinement
Obsidian (broken): 1.14.4, revision 69
Obsidian (working): 1.13.7, revision 68
