Obisidian always starts on the primary monitor
It seems like Obisidian always starts on the primary monitor, even if I put it on the secondary and close it from there. Next time it will happily start on the primary monitor again.
Is this intentional? And why?
Or is it a bug? It sure feels like one.
To narrow it down, what OS are you using?
I actually intentionally withheld that information, because as said, it might be a deliberate feature. If it is, then OS shouldn’t matter and it should be as I described on every OS. In that case, I just like to know why that is.
But since you’re asking: Windows 10.
Um, okay?
Anyway, on macOS if I fully quit Obsidian with one vault open on a secondary monitor, the same vault opens on the secondary monitor after a relaunch.
