a)
- Create a list
- Remove an item in the numbered list (and remove its empty new line)
b)
- Create a list
- Use the “Toggle numbered list” action on an item in the list
- a) Numbered lists should reorder from 1 after an item has been removed and are separated. Two lists that merge with no new line between should be considered one list, and reorder from 1.
- b) Numbered lists should reorder from 1 after using the “Toggle numbered list” action from the start of the list, and not the item position in the list.
Numbered lists do not automatically reorder after modification.
- Windows 10
- Default Help Vault
- Debug info
Obsidian version: v0.13.19
Installer version: v0.12.15
Legacy editor: off
Safe mode: on
