I’m using Obsidian 1.1.9 with the Note-Refactor extension installed. The Extension is activated and commands are visible in the obsidian command pane. Every time I want to start a refactor command (for example “Extract selection to new node”) I get a warning/error from “electron.app.obsidian” that tells me “Please use Note Refactor plugin in edit mode”. The command is not executed.
