Note properties disappear from file properties panel when navigated to from a canvas
  • Add a card to a canvas
  • On the card, link to a note with properties
  • Click the link to the note, the note’s properties don’t show up on the file properties panel but show up on the note
Yes
The note’s properties show on the file properties panel
The file properties panel is blank
Obsidian version: v1.4.13
Installer version: v1.4.13
Operating system: Darwin Kernel Version 22.6.0: Wed Jul 5 22:21:53 PDT 2023; root:xnu-8796.141.3~6/RELEASE_ARM64_T6020 22.6.0
Legacy editor: off
Plugins installed: 0
Plugins enabled: 0
CleanShot 2023-09-23 at 01.32.50
It only happens when the linked note is displayed in the same tab where the canvas was. If, for example, the canvas was pinned and the link opens on a new tab, the bug doesn’t appear.
thanks
will be fixed desktop v1.4.15
