Note Interface not adapted to iPhone 11 screen
when you create or open a note
Expected result: the entire user interface it should be adjusted to the screen size
when you try to write a note on iPhone 11 you notice that the user interface on the top (and also the text you write) is not adapted to the screen, so you you need to scroll to the right side if you want to see the remaining part of the note and user interface. It’s quite uncomfortable. I tried also on an Android phone and this bug does not appear.
iOS
  • Operating system: iOS 14
  • Obsidian version: 1.0.4
I am not sure I understand you problem. Can you post a screen recording in safe mode and without themes/css. Thanks.
