I try to delete this note:
but it always says, Filename cannot contain any of the following characters…
Does one of you know this issue?
It should not be possible to create a file with this characters in the first place.
Did you try to locate the file with your systems file-browser (e.g. Finder, Explore)?
If you delete the file with your file-browser, it should also vanish from Obsidian.
