Note Composer: Option to leave a block or heading embed when extracting a block or section
We strongly recommend you to search the forum with possible keywords before making a new feature request. If your request is very similar to an existing one, consider liking it and/or making a comment rather than making a new one. Once you’ve searched and determined that this is a new request, delete this line.
when extract a paragraph or section of a note to other note or new note, they only leave a link of that note in current note. this makes it hard to find the extracted note in current note in the future.
instead of just leaving a link to the extracted note, leave a section level or block level embed link to the extracted note in the current note.
example note:
note1:
# 123
456
after extraction of section # 123 to note 2:
note2
#123
456
note1
![[note2#123]]
The text in the “Current workaround” section was just an example demonstrating the request, not a workaround, so I moved it.
I came here looking for this feature in Note Composer.
I’ve been looking for workarounds with Community Plugins like Text Transporter, but have not found anything workable.
With Text Transporter I can embed a block from a current note into another note (but the formatting with soft and hard breaks doesn’t transport well), but not the other way around.
Revised the title (was “[feature request]add an option to embed the section level or block level link to the extracted section in current note”).
There currently exists an option to leave an embed in thisNote after extracting a block to thatNote, but the embed is of the entire thatNote, not just the extracted block.
Thanks. Revised the title again (was “Note Composer: Option to leave an embed instead of a link when extracting a section or block”).
