Not Seeing Properties In Reading Mode
When I create properties in an edit mode, I then want to see them in the reading mode of my note as well. But for whatever reason I cannot see them.
When I enable the reading mode, the Properties tab just disappears and the # and text, etc appears. but in edit mode both Properties and the # etc are there so what might be the problem?
I have tried looking into the setting of the app, onto reddit, on YouTube, google, everywhere but found nothing which would help me solve this issue.
There is a setting:
Also, it may depend on the theme you are using, so you need to check its settings or its Style Settings plugin settings.
I am using the default theme and have the option enabled to “visible”
